查看: 880|引用回復: 0
新手問題,用PROLUX 智能充電器 可以沖450的哩電麼?
發表於 2006-5-19 13:55 |只看該作者 |倒序瀏覽
(依板規.請勿連結其它拍賣區的網頁以免造成誤會,原連結網址恕刪)
Description:
Specfication:
Input :AC 110V OR 230V / DC 11~18V
Battery Type :Ni-Cd / Ni-MH / Pb / Li-Po
Battery Cell :
        Ni-Cd/Ni-MH 1 - 10 Cell (1.2V - 12V)
        Li-Po 1 - 4 Cell (3.7V - 14.8V)
        Lead-Acid(Pb) 2 - 6 - 12V
Charge Rate :0.3A ~ 5A (0.1A Per gradation)
Discharge Rate :2A (Constant current)
Character:
1. AC, DC are both compatible
  AC 110V or 230V switching power supply technology input
  DC 11V ~ 18V input usable
2. Two-line 16 characters dot matrix large LCD display
3. AC & DC plug sockets are removable
4. LCD display indicates the data of 1)Battery Type 2)Charge & Discharge & Charge after
  Discharge 3)Current (A) 4)Capacity (mAh) 5)Voltage (V) 6)Time (sec)
5. Deactivate and reactivate the beeper by using the SELECT button
6. Detect inversion of the battery automatically and input reverse protection
7. Built-in a DC cooling fan
8. Entire aluminum casing design - compact and portable
我看好像沒有分塊檢測充電,可是這個充電器功能看上去非常全面;所以想瞭解一下,如果450動力電(11.1V)沒問題的話,我就買了
謝謝阿
GMT+8, 2026-10-9 20:01
