查看: 1290|引用回復: 9
450 plus with gpro
發表於 2016-1-21 11:18 |只看該作者 |倒序瀏覽
Please help. my 450 plus change to use gpro but the servo does not work, I use 14SG I push the throttle stick(left stick) three servo work,but I push the right stick three servo not move,I think the wiring to gpro is not ok,I want to know 450plus ele ,pit ,ail servo to gpro which Ch, please help
發表於 2016-1-21 11:31 |只看該作者
本帖最後由 mazaku 於 2016-1-21 11:34 編輯
幫翻譯~ ^^a
樓主有發過中文... 可能是有某些原因~
「請幫忙. 我的450 PLUS改用Gpro後就無法運作, 我使用14SG推動油門搖桿(左搖桿)三個伺服器能動作, 但是我推動右搖桿三個伺服器則無動作, 我認為是設定有誤, 我想知道450 plus的ELE. PIT. AIL伺服器各是對應Gpro的哪個頻道, 請幫忙 」
發表於 2016-1-21 11:52 |只看該作者
這邊有Gpro的說明書電子檔, 可參考一下
http://www.align.com.tw/ManuaLib/Heli/flybarless/HEGPRO01.pdf
36
發表於 2016-1-21 12:23 |只看該作者
gpro跟3gx對應的孔位不一樣須看說明書做正確的對應
樓上m大有給說明書電子檔,看一下應就可明白哪裡設錯了
發表於 2016-1-21 13:35 |只看該作者
本帖最後由 lliu0130 於 2016-1-22 15:18 編輯
Hi Hw,
    Sorry about this forum will check that need to has three Chinese chars at least before I reply you. Thus, I wrote "新年快樂" - Happy Chinese New lunar Year to you. But, if you could read Chinese Chars that will good for communications.
    You could download GPro manual for reference that mazaku had mentioned in floor 3rd.
    Looks from tail boom to head. Elevator servo which locate behind the swash plate that mapping to CH1 in GPRO; Aileron servo which linkage rod link to front-right hand side linkage ball of swash plate that mapping to Ch3 in GPRO and Pitch Servo which linkage rod link to front-left hand side linkage ball of swash plate that mapping to CH2. Please make sure that you mapping to the right channel and choose "HR-3" swash type in GPro configuration utility.
Regards
Louis
39
發表於 2016-1-22 00:15 |只看該作者
先多謝各大大,由其是 Louis,我幾架机都是裝Gpro的,今次將450 plus轉Gpro本應無問題,但因一時失魂忘記了一些步驟,現在問題全部解決,多謝
24
發表於 2016-1-22 11:25 |只看該作者
問題解決就好~~可以爽飛囉!!!
16
發表於 2016-1-22 14:54 |只看該作者
遇到問題時~~可以重頭再檢查一遍~~~通常都是出錯在一些小細節上!!!
44
發表於 2016-1-22 15:10 |只看該作者
有問題除了發問也可以自己先照說明書蟲頭檢查一遍喔!!!
ALIGN T-REX 550E PRO DFC
ALIGN T-REX 450 PRO DFC
ALIGN T-REX 450 PLUS DFC
ALIGN => T6
FUTABA => 14SG
發表於 2016-1-22 20:46 |只看該作者
問題解決就好!
GMT+8, 2026-10-11 21:45
