查看: 5722|引用回復: 19
T-REX700DFC重要訊息公告
發表於 2012-1-21 16:24 |只看該作者 |倒序瀏覽
針對亞拓近期推出的700DFC改裝旋翼頭組,發生ㄧ件因使用者反應摔機及夾座臂連桿固定螺絲未確實鎖緊,造成高頻震動產生材料疲乏而導致從螺絲的牙紋根部斷裂案例。我們擔心有不可以預期的飛安疑慮,故連同600DFC改裝旋翼頭組修改了主旋翼夾座臂結構設計,並選用剛性與韌性更強的高碳鋼材質經過CNC切削而成的螺絲,讓結構強度更佳化,能有效避免螺絲損壞斷裂的問題。注意:在700DFC還沒替換改良零件之前請暫時不要飛行,造成您的不便,亞拓在此致上最深的歉意。
凡先前購買舊款亞拓700DFC改裝旋翼頭組的玩家,只要攜帶舊款700DFC主旋翼夾座臂與夾座臂連桿固定螺絲到原購買模型店或與代理商聯絡,即可免費更換新型夾座臂連桿固定螺絲與新型主旋翼夾座臂。
2012年1月21日起開始提供新品更換,請連絡您原購買處及模型店,如有相關技術問題可以E-mail到亞拓信箱發問,信箱位址如下[email protected]。
600FDC改裝旋翼頭組已是新的設計結構,請安心使用!
造成不便這處亞拓深感抱歉!也感謝飛友對亞拓的支持,祝大家 新春愉快!!!
Regarding Align's recently released 700DFC rotor upgrade assembly, there has been an instance reported customer where a loosely tightened bolt on the pitch link assembly caused high frequency vibration, resulting in material fatigue and bolt breakage from where the thread start. Due to the concern that this breakage can lead to unforeseen safety issue, Align has modified the grip linkage arm design of both 700DFC and 600DFC rotor upgrade assembly. In addition, the bolt has been replaced with one made from CNC'ed high carbon steel material for improved rigidity and strength, effectively avoids bolt breakage issue.           Caution: Please do not fly before the 700 DFC new parts have replaced.  We deeply apologized for all the inconvenience caused.
For customers who have already purchased the first version of Align 700DFC head upgrade set, please bring the main blade grip arm and the screw to where you purchased or the local distributors to exchange the newly designed screws and grips.  This replacement process will be start on 2012/01/21.  If you have any question, please contact with your distributors or mail to [email protected]
發表於 2012-1-21 16:28 |只看該作者
亞拓對產品的認真負責有目共睹,
發表於 2012-1-21 16:37 |只看該作者
優質負責的好廠商!!!
亞拓 給你按個 讚!
171
發表於 2012-1-21 17:07 |只看該作者
售後服務是很重要的亞拓
TEAM ALIGN 曾權
20
發表於 2012-1-21 17:35 |只看該作者
有問題立即改善的態度~有目共睹!
Facebook : Bobby Tsai
Business : 小蔡影像工作室
(萬般帶不走為有3D GO!)
發表於 2012-1-21 17:42 |只看該作者
售後服務,超高水準
已冇法維有法,已有限維無限,用3D來靜化都市人心靈
發表於 2012-1-21 20:42 |只看該作者
我也換新的了
Team Align
發表於 2012-1-21 21:27 |只看該作者
負責任的好廠商!!!
發表於 2012-1-21 23:25 |只看該作者
一流公司 !
一流作風 !
所以T-REX100 3G我已經等一年了,雖然希望早日到手,等待還是感到值得!
市面上有許多同級的可選,我仍不為所動!
542
發表於 2012-1-21 23:51 |只看該作者
舊版700 DFC 有玩家已經飛過10幾趟沒問題! 不過亞拓服務與重視安全觀念 真是令人讚賞O 感謝亞拓團隊 也讓模型店有個信心依靠  謝謝亞拓O
[新品已到 請有購買的飛友來店更換  也可寄送服務!] 謝謝
發表於 2012-1-22 00:18 |只看該作者
飛了2~30趟沒事,雖然要拆下更換,還是要感謝亞拓的負責
發表於 2012-1-22 16:42 |只看該作者
亞拓的用心.讓飛友們就甘心!!!!
發表於 2012-1-23 02:41 |只看該作者
雖然才裝上不到一個禮拜就拆,但有這樣的廠商玩的更安心。
不錯的商家值得鼓勵。
最近新加入了新成員 TREX-100 不怕下雨更不怕大太陽 呵呵
現有機種700DFC頂級版600DFC頂級版100X2
發表於 2012-2-4 20:44 |只看該作者
亞拓的售後服務揪甘心ㄟ
發表於 2012-2-4 21:28 |只看該作者
700DFC還沒替換改良零件之前請暫時不要飛行2012年1月21日起開始提供新品更換一直 到現在2/4還沒有拿到. 扳大:還要多久才ㄎ以拿到ㄚ
GMT+8, 2026-10-17 01:59
