- 註冊時間
- 2008-4-12
- 最後登錄
- 2018-6-6
- 在線時間
- 3870 小時
- 閱讀權限
- 50
- 積分
- 673
- 帖子
- 173
- 精華
- 0
- UID
- 22056
已經有人寫出自動建檔程序了..無須再用手動軟體去修改了..使用方法
原帖轉貼
http://bbs.5imx.com/bbs/viewthread.php?tid=388557&extra=page%3D1
Futaba T8FG 工程模式激活工具
1. 把SD卡放入電腦格式化 (無需空卡)
2. 把SD卡放入讀卡器,並啟動 T8FGService.exe 程序
3. 選擇SD卡對應的驅動器符
4. 點擊「OK」等操作完成
5. 彈出SD卡,插入T8FG中
6. 打開T8FG電源,工程菜單會自動顯示
7. 如果還需要使用這張卡存放模型數據,刪除TINYFS.IMG文件或在操作系統中格式化。
** 警告:小心使用工程菜單,自擔風險 **
Tools to create futaba T8FG service activator SD card.
1. Make sure the SD card was proper formatted by T8FG trasmitter.
(No matter there is model data in it)
2. Insert card to SD card reader and run T8FGService.exe
3. Select the correct drive where your SD card is in.
4. Click ok and wait the procedure complete.
5. Eject the card and insert into T8FG
6. Powre on T8FG and the service menu appears automaticly.
7. When your want reuse the SD card in T8FG to store model data. Just delete TINYFS.IMG in card root directory or format the card in OS.
** WARRING: OWN YOUR RISK TO MODIFY SERVICE MENU SETTINGS **
modify KEY.dat file to do other function. (Any string else to disable service function)
'T8FG TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T8FG TEST(LIMIT )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T8FG TEST(RST SS )' - Don't Known SS stands for
'FX-20 TEST(RST SS )' - Do service FX-20, Don't know SS.
'T8FG TEST(RST PCM)' - Don't Known detail, maybe reset PCM module locate
'FX-20 TEST(RST PCM)' - Do service FX-20, Reset PCM Module.
'T8FG TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T8FG TEST(TELEC )' - Don't known what's purpose
'T8FG SCREEN SHOT ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
'T8FG TEST SHOT ' - maybe simular to screen shot
This program can be used for T12FG too. Just use following code in KEY.dat instead.
'T12FG TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T12FG TEST(LIMIT )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T12FG TEST(RESET )' - Hard reset of the TX. All memory is cleared, total power on time is reset, product id is cleared, stick calibration is reset...
'FX-30 TEST(RESET )' - I don't have FX-30, so I never tried it. Don't know what it does.
'T12FG TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T12FG SCREEN SHOT ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
下 載地址:
http://starmoon.org.cn/share/software/RC/T8FGService.rar
[ 本帖最後由 sson0457 於 2010-6-19 01:35 編輯 ] |
