查看: 873|引用回復: 4
遙控器的 trim, sub trim (rudder) 是不是無用的
發表於 2010-4-20 17:29 |只看該作者 |倒序瀏覽
從網上文章 http://www.raptortechnique.com/gyroconfusion.htm 看到:
Can I use rudder trim
If you are using a heading hold gyro then the quick
answer is no. The reason is that heading hold gyros are looking for a centered command from the radio to keep the helicopter from rotating. If you move the rudder trim a few clicks one way or the other then a gyro in heading hold mode thinks that you wanting it to spin in that direction.
Example: Say you have switched to non-heading hold mode and the helicopter is rotating left so you add a little right trim until the helicopter is still. Now when you flip back to heading hold then you will find the helicopter now constantly rotates to the right.
So how do you make it so the helicopter is trimmed in both heading hold and non? This confuses a lot of people because they often do the setup out of order.
The first step is to center the trim and zero the sub-trim. Next with the gyro in heading hold mode adjust the sub-trim so the helicopter does not rotate. Normally this should be zero but due to small differences in the radios as well as some gyros you may find you have to adjust the sub-trim. The next step is to switch to non-heading hold and if the helicopter drifts, then adjust the rudder linkage. If the helicopter is drifting left then turn the link clockwise, opposite if drifting the other direction.
那麼, 可否說, 遙控器的 trim (rudder) 及 sub trim (rudder) 功能, 對直昇機來說, 是完全沒有用處的.
[ 本帖最後由 derek123 於 2010-4-20 17:31 編輯 ]
發表於 2010-4-20 21:28 |只看該作者
我用的是鎖定式陀螺儀GP750,而且我飛行全程使用鎖定模式.
所以RUDDER TRIM對我來說是用不到的.
發表於 2010-4-20 22:26 |只看該作者
如果調整了不知道會不會怎麼樣
發表於 2010-4-20 22:41 |只看該作者
我試過真的無分別!
發表於 2010-4-21 08:53 |只看該作者
原帖由 h53021 於 2010-4-20 22:26 發表
如果調整了不知道會不會怎麼樣
如果調整了, 就會像文中舉例一樣 "...Example: Say you have switched to non-heading hold mode and the helicopter is rotating left so you add a little right trim until the helicopter is still. Now when you flip back to heading hold then you will find the helicopter now constantly rotates to the right."
不單只這樣, 我以前在subtrim 中調了小小 (約為 4), 當機子每次接電時, gyro (GY 401) 有時會出現閃燈 (正常應該是長著).
後來有高手提點, rudder 的 subtrim 一定要 set 做 0, 自前以後, 每次接電, gyro 都會長著燈, 表示已在 Heading Hold 模式.
GMT+8, 2026-10-18 23:01
