查看: 1069|引用回復: 5
請教dsx7控600NSP上陀螺儀和定速G600的設置問題.
發表於 2010-1-13 14:11 |只看該作者 |倒序瀏覽
       求助各位高手:dsx7控在600nsp上陀螺儀401和定速G600的設置問題剛入手dsx7控,研究學習了很多帖子,發現大多都是電直設置,不需定速儀速,不知dsx7加上g600定速要怎樣設置,有設置成功的高手貼出來分享一下,謝謝。
       參照了http://www.helifreak.com/showthread.php?t=49362設置,其中第2條set AUX2 to INH?看好多人都不是設置為INH,如果按此設置,陀螺儀該如何設置,請教了。
2. Scroll to Input Selct menu and set AUX2 to INH
3. Turn OFF and the turn ON the radio again.
4. Go to the programming menu. (Press down+select)
5. Scroll to PROG.MIX1 menu. We are going to setup here the desired headspeed for Normal mode. Set it to make it look like this: AUX2> AUX2 ON -- if this says OFF, your flight mode switch is not in normal RATE: +80% --- for 1882 rpm headspeed 0% SW: F-NR OFFSET: 0 You set your RATE % based on the headspeed you want for normal mode. Refer to the table chart that came with the GOV.
6. Scoll to PROG.MIX2 menu. We are going to setup here the desired headspeed for IDLE1 mode. Set it to make it look like this: AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE1 Rate +90% -- for 2024 rpm headspeed 0% SW:F-S12 OFFSET: 0 Again, you set your RATE% based on the headspeed you want for IDLE1.
7. Scroll to PROG.MIX3 menu. We are going to setup here the desired headspeed for IDLE2 mode. Set it to make it look like this: AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE2 RATE: +10% -- NOT 100% for 2171 rpm headspeed 0% SW:F-S2 OFFSET: 0 NOTE: IDLE2 uses the base number from IDLE1 and add it's own value to it. So 90% (from IDLE1) + 10% = 100%
(萬般帶不走為有3D GO!)
發表於 2010-1-13 22:11 |只看該作者
回復 1# 的帖子
我的DX7SE是這的,不支DSX7是不是相同
AX2=F.MOD GEAR=GYRO
AX2=F.MOD GEAR=GYRO
油門CUT
油門CUT
跟圖1PRO MIX 2 才可開2段i豆
已冇法維有法,已有限維無限,用3D來靜化都市人心靈
發表於 2010-1-14 09:11 |只看該作者
感謝XBOY,週末試一下看看
禁止訪問
發表於 2010-1-14 09:16 |只看該作者
看什麼看,沒看過帥哥阿!
(萬般帶不走為有3D GO!)
發表於 2010-1-14 12:23 |只看該作者
回復 4# 的帖子
MIX2%數量是由MIX1相加嗎=No
MIX1設50%,MIX2設50%再IDEL2下是算100%嗎=Yes
(萬般帶不走為有3D GO!)
發表於 2010-1-14 12:33 |只看該作者
圖片是以700N+AR7100R    -83=1900RPM
                                                  -88=2000RPM
                                   OFFSET-80=開2段IDEL
               以600N+AR9000    +95=1950RPM
                                                 -105=2150RPM
                                    OFFSET-90=開2段IDEL
GMT+8, 2026-10-12 19:46
