查看: 3386|引用回復: 17
陀螺儀也有山寨機
發表於 2009-3-2 03:14 |只看該作者 |倒序瀏覽
GY401 也有山寨機
COLCO GY400 AVCS Rate Gyro
for helicopter
Specification:
Control System :Digital advanced PI (Proportional Integration) Control
Gyro sensor:SMM system vibration gyro (Silicon Micro Machine)
Operating voltage:+4 to +6VDC
Operating temperature range:-10 degree to +45 degree
Function:Gyro operation direction switch, DS mode switch, Control delay trimmer, Limit trimmer Remote gain control, AVCS/normal mode switching
Dimensions:21.8 X 21.8 X 19.00mm
Weight:15g (including connector)
Package Weight: ~65g
Features:
AVCS system
Since rudder trim changes caused by wind and other meteorological changes and front, rear, forward, reverse, and other helicopter attitude changes are automatically cancelled, tail (rudder) operation is easy, making it perfect for 3D flight.
SMM gyro sensor
Use of newly developed extremely low drift SMM(Silicon Micro Machine) gyro sensor virtually eliminates rudder trim changes during flight.
Integrated, compact, and lightweight
Compact size (21.8x21.8x19.0mm) and light weight (15g) realized by high density mounting technology.
Conductive resin case
Conductive resin case improves EMC (electrostatic and electromagnetic interference) resistance.
AVCS Gyro
Conventional gyros send control signals to the rudder servo only when the tail of the helicopter moves. When the tail stops moving, the control signal from the gyro becomes zero. Conversely, the AVCS gyro continues to send control signals to the servo even when the helicopter stops moving. The following sequentially describes the conventional gyro and the AVCS gyro.
Operation of AVCS Gyro
Basic operation is described by considering the case when the helicopter is hovering under cross-wind conditions. With a conventional gyro, when the helicopter encounters across-wind, the force of the cross-wind causes the tail of the helicopter to drift. When the tail drifts, the gyro generates a control signal that stops the drift. When the tail stops drifting the control signal from the gyro becomes zero. If the cross-wind continues to cause the tail to drift in this state, the "stop'' operation is repeated until the tail faces downwind. This is called the "weathervane" effect.
Conversely, with an AVCS gyro, when the helicopter encounters a cross-wind and the tail drifts, a control signal from the gyro computes the drift angle and constantly outputs a control signal that resists the cross-wind. Therefore, drifting of the tail can be stopped even if the cross-wind continues to effect the helicopter. In other words, the gyro itself automatically corrects(auto trim) changes in helicopter tail trim by cross-wind. Considering operation of an AVCS gyro, when the tail of the helicopter rotates, the servo also rotates in accordance with angle of rotation of the tail. When the tail stops rotating, the servo judges that it has stopped in that position. This is the auto trim function.
Item Included:
colco GY400 Head Lock Gyro
English User Manual
發表於 2009-3-2 08:16 |只看該作者
有人試過嗎...........
發表於 2009-3-2 09:52 |只看該作者
401少了個1
哎呀.差矣
發表於 2009-3-2 10:37 |只看該作者
帥喔,無所不仿,頭腦跟技術都挺不錯...怎麼不用在正面的方面呢????
3D.......NO WAY
發表於 2009-3-2 12:35 |只看該作者
可能對他們來說這就是 正面的吧 會不會是就像 GY240改401 那種樣子的東西阿 香港朋友還寄一顆 假的9254給我用後來只能拿來推油門  外觀一模一樣 但是轉起來聲音不同  爾且 外殼材質也不同 買的時候要小心摟
發表於 2009-3-2 13:27 |只看該作者
.........S9254有仿冒品.........
發表於 2009-3-2 14:06 |只看該作者
阿六牌的仿冒品.............
Team Align
發表於 2009-3-2 16:22 |只看該作者
阿六的真厲害!~~~
發表於 2009-3-2 16:32 |只看該作者
可怕 ! 以後買東西真的要很小心了 !
發表於 2009-3-2 17:06 |只看該作者
.........S9254有仿冒品.........:
遙控器JR PCM9X2
發表於 2009-3-2 17:34 |只看該作者
見怪不怪啦,山寨風行,
發表於 2009-3-2 17:38 |只看該作者
GY400才170元人民幣
不知道會不會有人 像5樓遇到的情形一樣 用正版的銘牌貼在山寨機 再放到拍賣上!!
現在買中古品的人 要很小心了!!
FD爽飛幫
發表於 2009-3-2 17:43 |只看該作者
這個厲害~~~~~
~~~~~但伺服機搞到一模一樣就不大好了吧~~~~~~~~~
發表於 2009-3-2 18:09 |只看該作者
好像哦
怕怕
450PRO+600N+PRO600E+700E
初學者努力學習鐘擺停懸
發表於 2009-3-2 19:59 |只看該作者
這已經司空見慣了...不過用在具有殺傷力的直昇機上,還是要多多三思...
GMT+8, 2026-10-10 11:50
