查看: 1474|引用回復: 3
亞拓DS610,620香港有貨了
發表於 2008-11-17 23:40 |只看該作者 |倒序瀏覽
多度售馨的亞托DS610,DS620新貨已到香港
Trex-250,450,500,600,700,,哈哈
Futaba T14Mz -T/R-60th / 7C (2.4G),,哈哈哈
發表於 2008-11-17 23:48 |只看該作者
香港飛友有好東西用,又可爽飛了...
17
發表於 2008-11-18 04:20 |只看該作者
CCPM舵機
610裝700
620裝600
速度快又有力~都是爽噴......
***ALIGN TEAM***
發表於 2008-11-18 09:20 |只看該作者
再貼一次 之前在電子設備區的文:
好東西 和 大家分享:
Dear 大大:
我看了你的留言說國外對DS610這顆的平價反應很兩極 所以上網google了 一下
在應該算具指標性的Helifreak論壇上看到 都是正面的ㄝ
http://www.helifreak.com/showthread.php?t=87155&page=4
擷取幾段給您做參考
I've used them on my T700 for about 30 flights and a flying buddy been using them on 8V on his 700 for about 50 flights - so far so good - I tortured one to death on Bob's Tech room under using CBDANES servo tester
IMHO these servos gonna do to Futaba/Hitec what the T600 did to the Raptor 50 !
__________________
John
主要是說這位玩家用DS610在他的TREX700上已經飛了30趟 他的飛友甚至用8V的來飛 也已經飛了50趟 so far so good (到目前為止都很好), 他用CBDANES 伺服測試機把一顆折磨死了 (我也不曉得他沒頭沒腦的說這各幹麻)
最後是說 IMHO (In My Humble Opinion)照字義上來翻是 我個人的淺見 這幾款伺服會對Futaba和Hitec造成 Trex600N 對 Raptor 50的影響 (至於是甚麼影響 大家各自發揮囉)
以下為另一飛友的po文
10-12-2008, 10:32 PM   #33
tick77
this servo is being sold as a tail rotor servo as well. so yes you can use it for that.
I just had a bad wreck with servo doing a caos close to the ground and the servos didn't get phased by it. metal gears all around very smooth transition and plenty of power for a price of $67 a pop. it can't be beat. I took a look inside and the circuit board and solder joints are well made. no sloppy work at all. ( I used to work for SONY electronics in greensburgh PA.) I know a good solder joint when I see one. definetly recommend these servos.
and as far as I'm concerened this post will probably never get old. only more popular....:-)
__________________
you will only crash so many times, before you get it right
k77
View Public Profile
Find More Posts by tick7
10-21-2008, 12:32 PM
  #38
twohsieh
Any further update on these servo?
twohsieh
View Public Profile
Find More Posts by twohsieh
10-21-2008, 05:16 PM   #39
tick77
Quote:
well since the last post on the 13th I've put another 23 flights on it and they're are the best servo's I've ever used. I'm not even sure how many flights total that is ( lost track ) , but I'm well over 70 now with 2 crashes. no signs of wear, they center perfectly and now I'm thinking about buikding a second 600E soon, as a back up for when I go to air shows. I'm just affraid that the second one will become a shelf queen .
the castle creations BEC's are the best inventions yet they perform very well even under serious load and have had no hick ups with them either.
__________________
tick77第一篇文寫到DS610的超值價格 並且拆開裡面看過 不管是電路板或是銲錫點都做的很好 , 他曾經在SONY 電子工作過 他一眼就能看出好的solder joints(銲錫接點) 他絕對推薦這顆伺服
後來隔了數天後又有另外的飛友問他 後續如何
他就po了第二篇文,內容如下:
他之後又再飛了23趟,他表示DS610是他用過最好的伺服.他說他也不曉得總共飛了幾趟了 但是他說他已經飛了至少超過70趟並摔了兩次 但目前伺服看來皆無耗損(wear)並且中立點還是很準 (center perfectly) 接下來就是在說Castle電變的事
以上給您參考!!!
[ 本帖最後由 artvox 於 2008-11-18 09:29 編輯 ]
GMT+8, 2026-10-13 15:47
