查看: 1909|引用回復: 5
DX7se
(萬般帶不走為有3D GO!)
發表於 2008-10-16 22:00 |只看該作者 |倒序瀏覽
DX7se  2048 11ms
http://www.spektrumrc.com/Products/ProductGallery.aspx?ProdID=SPM2731
DX7特別版發射機只有MD2
Overview 概覽
SE—Special Edition…And Serious Edge硒特別版...和嚴重的邊緣
Take the already groundbreaking features of Spektrum』s DX7 radio system, including the unmatched clarity of DSM2™, ModelMatch™ and ServoSync™…then take it to the next level specifically for cutting edge heli pilots.已經採取突破性的特點Spektrum的DX7無線電系統,其中包括無與倫比的清晰的DSM2 ™ , ModelMatch ™和ServoSync ™ ...然後帶到一個新的水平特別是尖端螺旋飛行員。 The result is the DX7se.其結果是DX7se 。 It』s about way more than looks.它是關於道路超過期待。
The Search for Speed Stops Here尋找高速停止在這裡
The DX7se takes Spektrum』s already incredible speed and gives it a shot of adrenaline.該DX7se需要Spektrum已經難以置信的速度和給它一桿腎上腺素。 Combining an 11ms frame rate with a latency range that』s 50% less than our nearest competitor delivers the absolute fastest air radio on the market with the most consistent response.結合一個11ms的幀速率的潛伏期範圍的50 %不到離我們最近的競爭對手提供的絕對速度最快的空中無線電市場上最一致的反應。 And that low latency range is attributable directly to Spektrum』s unique DSM technology.和低延遲範圍,原因是直接向Spektrum獨特的電力需求側管理技術。 In the pursuit of even more precise control, heli pilots are looking for an extreme link between their radio systems and control surfaces, and the DX7se offers just that.為了實現更加精確的控制,直升機飛行員正在尋找一種極端之間的聯繫的無線電系統和控制面,和DX7se提供了這一點。 No other radio system has a lower latency, resulting in a responsiveness that is nearly telepathic without compromising the RF link quality.沒有任何其他無線電系統具有較低的延遲,導致反應幾乎是telepathic又不損害射頻鏈路質量。
Resolution—It Means More than Clear Pictures決議,這意味著超過清晰圖片
The DX7se boasts ultra-high 2048 resolution, providing precision to go along with its unprecedented speed.該DX7se擁有超高的2048號決議,提供精確到連同其前所未有的速度。 What does that doubled resolution mean for you?這是什麼意思決議一倍嗎? It means the most precise feel you could possibly imagine from a radio system.這意味著最精確的覺得你可能想像的無線電系統。
The increased resolution of the DX7se makes the difference between standard control and gliding smoothness, eliminating any notched feelings or hesitation.增加解決DX7se使標準的差異控制和滑行平穩,消除任何缺口感情或猶豫。 Control inputs and responses are so smooth, you』ll swear that you』re flying on a hard-wired connection.控制投入和反應如此順利,你會發誓你飛行的硬線連接。 And all of this with the incredible range and interference-free control of Spektrum™ DSM2.而所有這一切都與難以置信的範圍和無干涉控制Spektrum ™ DSM2 。
The Speed You Need速度你需要
One thing is undeniable—if you want the fastest response time and lowest latency for your high-performance heli setup, the DX7se is the only system to choose.有一件事是不可否認的,如果你想獲得最快的響應時間和最低的潛伏期為您高性能的螺旋設置,在DX7se是唯一的制度選擇。 Take the controls and see for yourself.採取控制和瞭解自己。 Only Spektrum can offer this connected feel.只有Spektrum可以提供這種連接的感覺。
Key Features主要特點
Throttle Curve (3) (5-point mix)油門曲線( 3 ) ( 5點混合)
Pitch Curve (4) (5-point mix)瀝青曲線( 4 ) ( 5點混合)
Revolution mix革命組合
Gyro Sensing陀螺傳感
Swashplate Type (1-servo normal, 2-servo 180, 3-servo 90, & 3-servo 120)斜盤式類型( 1伺服正常, 2伺服180個, 3個伺服90 , & 3伺服120 )
Programmable Mix (3)可編程混合( 3 )
20-Model Memory 20模型記憶
Model Select產品型號選擇
Model Name型號名稱
Model Type Select示範類型選擇
Model Reset示範重置
Throttle Recovery油門恢復
Input Select (Switch for Aux 2 & Gear Channels)輸入選擇(開關奧克斯2 &齒輪頻道)
Dual Rate Switch Select雙率切換選擇
Timer定時器
3-Axis (Dual Rate & Expo) 3軸(雙速率博覽會)
Exponential指數
Servo Reverse伺服反向
Sub Trims小組裝飾
Travel Adjustments旅行社調整
Servo Monitor伺服監控
Special Ediction neck strap included特別Ediction包括頸部帶
Note: the trainer function has been removed from the DX7se註:培訓功能已經從DX7se
已冇法維有法,已有限維無限,用3D來靜化都市人心靈
Team Align
發表於 2008-10-16 22:08 |只看該作者
謝謝大大的分享!!!~~~~~~~~~~
發表於 2008-10-16 22:20 |只看該作者
ALAN手上那一支好像就是2048版的~
現在要正式發售了
我想誰都沒想到這DX7會如此瘋狂的熱賣吧!
(萬般帶不走為有3D GO!)
發表於 2008-10-16 22:22 |只看該作者
回復 3# 的帖子
發表於 2008-10-16 22:40 |只看該作者
高解析傳輸速率!!多謝大大熱心分享...
發表於 2008-10-16 22:41 |只看該作者
因為ALAN的代言所以熱賣可想而知 呵呵
GMT+8, 2026-10-10 12:47
