查看: 1435|引用回復: 8
FUTABA數位伺服機3156
發表於 2008-8-2 14:26 |只看該作者 |倒序瀏覽
好幾台小暴龍都用了65MG+401+9650(改9257齒輪),問題倒是沒有啦...但總覺得伺服機還是數位好一點,中位準一點,最近又要裝一台450打算用FUTABA3156+600E陀螺儀,不知各位前輩是否有人用過FUTABA9156伺服機,是否可以給點意見...
謝謝...
發表於 2008-8-2 15:00 |只看該作者
3156哪而有得買啊
發表於 2008-8-2 16:16 |只看該作者
回復 2# 的帖子
我在日本買到了...金屬齒,速度跟扭力好像都比65MG好一點?!只是看起來有點脆弱,真怕一摔就掛了,65MG真的是很耐摔...
發表於 2008-8-2 18:24 |只看該作者
S3156..  看它的資料.. 是arumi(鋁)齒....
我想應該還沒人用過..
若是大大使用的話.. 記得請分享你的使用心得喔....
藍天使
發表於 2008-8-3 00:36 |只看該作者
真利害
感謝分想
藍天使
發表於 2008-8-3 04:38 |只看該作者
Notes from the Tech Department
This is the Futaba S3156 Micro Digital Metal Gear Servo.FEATURES: For small electric powered aircraft modelsINCLUDES: Futaba S3156 servo, 0.79" (20mm) long 4-point horn, 1.6" (40mm) long4-point horn, 0.79" (20mm) diameter round horn, four 2x11mmmounting sccrewsOne year limited warrantyREQUIRES: Installing in model, connecting linkage and connecting to receiverOrder DUBM6924 if mounting hardware is neededSPECS:    Torque: 28 oz-in (2.0 kg-cm) @ 4.8V33 oz-in (2.4 kg-cm) @ 6VSpeed: .13 @ 4.8V.11 @ 6VSize: .8.5 x.43 x 1.3" (21.8 x 11 x 28.7mm)Weight: .3 oz (9.3g)COMMENTS: Do not use this servo with gas powered models or models requiringhigh torque.Do not exceed 6V supply voltage or apply high load to servo.Do not use standard size servo horns. Use horns designed only formicro servos.For replacement horns use part numbers FUTM2005 or FUTM2038, theyfit very tight but they will work.jxs 2/12/08ir/jxsupdated jpg 6/9/08
發表於 2008-8-3 04:44 |只看該作者
3153MG比較好看 但扭力略輸3156MG
[size=+1]Notes from the Tech Department
This is the Futaba S3153 Micro Digital Metal Gear Servo.FEATURES: For small electric powered aircraft modelsOne year warrantyINCLUDES: Futaba S3153 Micro Digital Metal Gear Servo with J-connector, 0.79"(20mm) diameter four point servo horn, 0.79" (20mm) diameter roundhorn, 1.6" (40mm) diameter four point servo horn, servo mountinghardware and instruction and warranty sheetsREQUIRES: Installing in model, attaching linkage and plugging into receiverSPECS:    Torque: 19 oz-in @ 4.8V,  24 oz-in @ 6VSpeed: 0.13 sec/60° @ 4.8V, 0.11 sec/60° @ 6VSize: 0.9 x 0.4 x 0.8" (21.8 x 11 x 20.3mm)Weight: 0.32oz (9.6g)Lead Length: 6.7" (170mm)COMMENTS: Do not use this servo with gasoline powered models, large gliders orother models requiring high torque.jxs 12/19/07ir/jxsupdated jpg 5/14/08
發表於 2008-8-4 07:47 |只看該作者
早就用過的東西,比65MG耐摔很多。因為下來最多就是斷舵臂,不會像65MG下來燒電機或者掃齒
發表於 2008-8-5 16:18 |只看該作者
回復 8# 的帖子
感謝訊息提供
GMT+8, 2026-10-19 21:39
