查看: 1581|引用回復: 6
Spartan DS760 Firmware
發表於 2008-7-14 18:19 |只看該作者 |倒序瀏覽
小弟逛網站時不小心發現的!
有用ds760的人可以上網更新一下囉!
Device: Spartan ds760
Firmware version: 1.08
Notes: See FAQ for firmware info. User data will be erased.
小暴龍SE/3700kv馬達/35x電變/65mg*3/DS760+9650改9257齒輪
DSX9 2.4G+AR6200
Team Align
發表於 2008-7-14 18:38 |只看該作者
感謝分享!!~~~~~~~~~
發表於 2008-7-14 21:50 |只看該作者
謝謝分享...
發表於 2008-7-14 22:03 |只看該作者
不知道更新後有何差別??
謝謝分享可是760以賣的
發表於 2008-7-14 22:10 |只看該作者
原帖由 kubin 於 2008-7-14 22:03 發表
不知道更新後有何差別??
‧ Spektrum power on glitch fix. A small delay was added before the ds760 starts to monitor the gain input. This masks the power on glitch of Spektrum receivers that sometimes makes the ds760 enter setup mode.
‧ Redundant data storage. Two copies of the gyro configuration data are now stored. If one copy fails to validate on power on the ds760 will automatically try the other and repair the first. If corrupt data are repaired an entry is added to the gyro's log.
‧ Enhancements to bumpless reboot handling and logging. This update improves the gyro's ability to tolerate severe static hits and deep brown-outs by performing a controlled restart in an already calibrated state using saved calibration data. The restart takes around 1/5th of a second and it most cases won't even be noticed by the pilot or it may appear as a slight tail twitch. If a bumpless restart takes place an entry is added to the gyro's log.
‧ Firmware version viewed via LED. Firmware version is shown to the user as a series of short and long LED flashes.
‧ Improvements to communication protocol. Data validation has been added which will enable safe independent development of gyro configuration software for other platforms.
DSX9 2.4G+AR6200
反美手3D學習組
發表於 2008-7-14 22:35 |只看該作者
回復 1# 的帖子
感謝大大的分享!
飛機J3小黃*1 服役中
翱翔 & 競速機翼*1服役中
GMT+8, 2026-10-11 19:45
