查看: 1446|引用回復: 1
Difference between KX850160A and KX850172A
發表於 2008-1-31 17:13 |只看該作者 |倒序瀏覽
3S 2100 mah 20C. Look like the spec the same. What is the difference between them?
發表於 2008-4-23 03:42 |只看該作者
Both body cells are the same. Only Balancer connector is different.
KX850160A for Align RCE-6BA Balancer
KX850172A for TP Balancer
You can use the Balance adapter ( K10384A) to connect Align Balancer if you use TP type connector.
GMT+8, 2026-10-11 04:11
