查看: 2349|引用回復: 13
亞拓定速器配 JR-2720 或 DX-7 遙控器設定成功了
發表於 2007-11-27 10:17 |只看該作者 |倒序瀏覽
前輩大大們     後輩是飛600N 遙控器用 DX-7 功能與 JR-2720 同 目前定速只會設 開與關 NORM過30%會啟動定速 常因誤以為在IDO模式..........就給它.....翻過去.......啊.......啊.......手不夠快............就給它摔了..........
請教前輩們 如何將定速器設定成 NORM 關 及 ST-1 ST-2 兩段定速     感激不儘
[ 本帖最後由 tincor2005 於 2007-11-30 19:21 編輯 ]
發表於 2007-11-27 19:30 |只看該作者
Use Prog Mixing 1 &2.
Quote from helifreak/ RR
1. Install the governor per the manual. I'm using a DX7/AR7000 and the yellow sign wire is connected to AUX.
2. Set ATV for AUX2 to +100%/-100%
3. Set throttle curve to linear - 0-INH-50-INH-100
4. With the throttle stick on its lowest position, turn ON the radio.
5. Turn ON receiver and wait for the governor light to turn Green. When it's green, press the SET button on the governor for about 3 seconds until the GOV light starts to blink. Release the SET button then move the throttle stick to its highest position. The GOV light will turn OFF for a second then turn solid GREEN.
At this point, calibration is done. Verify that GOV is sensing the magnet by manually rotating the starter shaft with a 6MM allen wrence or just use your starter shaft. The lights on the GOV should turn OFF when one of the 2 magnets is directly under the sensor. (NOTE: only one of the two magnets should make the GOV light OFF. If you have both of the magnets turn OFF the GOV light, the magnets are installed incorrectly.)
PROGRAMMING THE DX7
1. Go to the master menu. (Press down+select and power ON)
2. Scroll to Input Selct menu and set AUX2 to INH
3. Turn OFF and the turn ON the radio again.
4. Go to the programming menu. (Press down+select)
5. Scroll to PROG.MIX1 menu. We are going to setup here the desired headspeed for Normal mode. Set it to make it look like this:
AUX2> AUX2 ON -- if this says OFF, your flight mode switch is not in normal
RATE: +80% --- for 1882 rpm headspeed
0%
SW: F-NR
OFFSET: 0
You set your RATE % based on the headspeed you want for normal mode. Refer to the table chart that came with the GOV.
6. Scoll to PROG.MIX2 menu. We are going to setup here the desired headspeed for IDLE1 mode. Set it to make it look like this:
AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE1
Rate +90% -- for 2024 rpm headspeed
0%
SW:F-S12
OFFSET: 0
Again, you set your RATE% based on the headspeed you want for IDLE1.
7. Scroll to PROG.MIX3 menu. We are going to setup here the desired headspeed for IDLE2 mode. Set it to make it look like this:
AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE2
RATE: +10% -- NOT 100% for 2171 rpm headspeed
0%
SW:F-S2
OFFSET: 0
NOTE: IDLE2 uses the base number from IDLE1 and add it's own value to it. So 90% (from IDLE1) + 10% = 100%
8. Exit programming menu and verify that when you flick the AUX2 switch on your radio, you can turn ON (green) or turn OFF (red) the governor. Take note which way your switch turns the GOV ON/OFF. If necessary, you can reverse AUX2 from the reversing sw. on the radio.
Thats it and go have some fun.
Special thanks to george0079 of RR.
__________________
Anthony
發表於 2007-11-27 21:12 |只看該作者
回復 #2 tungym 的帖子
謝謝你的好意… 但是真的有看…沒有懂… 它真的認識我… 我也真的不認識它(全英文)啦!
.....遙控漫長的不歸路……
現役(幻想中)…Futaba t14mz
      Heli: Shuttle Sceadu evoluton 50 /s9206*3/s9101/Gy601/s9256/OS.50sx-h ring.hyper/三鐵3D
                                              /Coolpower30%
發表於 2007-11-27 21:29 |只看該作者
原帖由 1024 於 2007-11-27 21:12 發表
說的好  因為我也不認速它啦
什麼手/美國手
中暴龍/500:5254MG*3 G770T DS8900
動 力/電機
50龍/翼手龍
動 力/OS
發射器/JR9XⅡ
頻    率/72頻
顏 色/透明
花間一壺酒....相期邈雲漢
發表於 2007-11-27 22:10 |只看該作者
雞婆來了 電腦翻的 哇勿宰
使用混合 1&2 的食物。 {使用食物混合 1&2.}
從 helifreak/RR 引述
1. 每手冊安裝管理者。 我正在使用 DX7/AR7000 和黃色的符號電線被連接到 AUX。
2. 為 AUX2 設定高階電視到 +100%/-100%
3. 對線性的固定節流閥曲線- {設定節流閥對線性的曲線- / 固定的節流閥彎到線性-}  0 INH-50 的-INH-100
4. 藉由在它最低的位置上的節流閥樹枝,打開收音機。 {與節流閥在它最低的位置上黏住,打開收音機。 / 藉由節流閥樹枝在它最低的位置上,打開收音機。}
5. 打開接收器而且等候管理者光變綠色的。 {輕裝地打開接收器而且等候管理者變綠色的。 / 打開接收器而且等候管理者點燃變綠色的。}  當它是綠色的時候,按在管理者上的固定的按鈕大約 3 秒之久直到 GOV 光開始眨眼。 {當它是綠色的時候,強迫管理者接受固定的按鈕大約 3 秒之久直到 GOV 光開始眨眼。 / 當它是綠色的時候,按在管理者上的固定的按鈕大約 3 秒之久直到 GOV 輕裝地開始眨眼。 / 當它是綠色的時候,強迫管理者接受固定的按鈕大約 3 秒之久直到 GOV 輕裝地開始眨眼。} 然後移動節流閥樹枝到它最高的位置,放開固定的鈕扣。 { 然後放開固定的鈕扣移動節流閥樹枝到它最高的位置。 / 然後放開固定的鈕扣移動節流閥黏住它最高的位置。}  然後轉堅硬的格林, GOV 光將關掉秒。 {然後變堅硬的綠色, GOV 光將關掉秒。 / 因為秒然後轉堅硬綠色, GOV 光將關掉。}
此時,口徑測定被做。 GOV 正在測知磁鐵的證實被用手用 6MM allen wrence 或者僅僅替換起動器軸使用你的起動器軸。 當 2個磁鐵之一直接地是在感應器之下的時候,在 GOV 上的光應該關掉。 {當 2個磁鐵之一直接地是在感應器之下的時候,光在 GOV 上應該關掉。 / 當 2個磁鐵之一直接地是在感應器之下的時候,在 GOV 上的光應該關掉。 / 當 2個磁鐵之一直接地是在感應器之下的時候,光在 GOV 上應該關掉。}  (附註: 只有二個磁鐵之一應該輕裝地走開製造 GOV 。 如果你走開讓兩個磁鐵都轉向 GOV 光,磁鐵不正確地被安裝。) {如果你離開 GOV 光讓兩個磁鐵都轉向,磁鐵不正確地被安裝。)}
規畫 DX7
1. 去主人的菜單。 (刊物墬落+選擇和力量在)之上 {(刊物向下的+選擇和力量在)之上 / (刊物下來+選擇和力量在)之上}
2. 捲動輸入對 INH 的 Selct 菜單和固定的 AUX2
3. 關掉和那再一次打開收音機。
4. 去規畫菜單。 (刊物墬落+選擇) {(刊物向下的+選擇) / (刊物下來+選擇)}
5. 捲動以訓導長身份訓導。混合 1份菜單。 我們對於正常的模態正在在這裡去裝置被需要的 headspeed 。 {我們正在為正常的模態去裝置這裡被需要的 headspeed 。 / 我們正在在這裡去裝置被需要的 headspeed 對於正常的模態。 / 我們正在去裝置這裡被需要的 headspeed 對於正常的模態。}  設定它做到看起來像這一樣:
AUX2> AUX2 在-之上- 如果這走開說,你的模態班機開關不在常態中 {如果這走開說,你的模態班機開關不是在常態}
比率: +80%--- 對於 1882 轉/每分 headspeed
0%
SW: F-NR
抵銷: {彌補:}  0
你設定你的比率%基於你為正常的模態想要的 headspeed。 {你設定你的比率%基於對於正常的模態你想要的 headspeed。 / 你設定你的比率%基於 headspeed 你為正常的模態想要。 / 你設定你的比率%基於 headspeed 你想要對於正常的模態。}  提及和州長一起來的桌子圖解
6. Scoll 以訓導長身份訓導。混合 2份菜單。 我們對於懶惰的 1個模態正在在這裡去裝置被需要的 headspeed 。 {我們正在為懶惰的 1個模態去裝置這裡被需要的 headspeed 。 / 我們正在在這裡去裝置被需要的 headspeed 對於懶惰的 1個模態。 / 我們正在去裝置這裡被需要的 headspeed 對於懶惰的 1個模態。}  設定它做到看起來像這一樣:
AUX2>AUX2 在-之上- 如果這走開說,你的模態班機開關不是懶惰的 1
估價 +90%-- 對於 2024 轉/每分 headspeed
0%
SW:F-S12
抵銷: {彌補:}  0
再一次,你設定你的比率%基於你想要的 headspeed 為懶惰的 1. {再一次,你設定你的比率%基於 headspeed 你想要為懶惰的 1.}
7. 捲動以訓導長身份訓導。混合 3份菜單。 我們對於懶惰的 2個模態正在在這裡去裝置被需要的 headspeed 。 {我們正在為懶惰的 2個模態去裝置這裡被需要的 headspeed 。 / 我們正在在這裡去裝置被需要的 headspeed 對於懶惰的 2個模態。 / 我們正在去裝置這裡被需要的 headspeed 對於懶惰的 2個模態。}  設定它做到看起來像這一樣:
AUX2>AUX2 在-之上- 如果這走開說,你的模態班機開關不是懶惰的 2
比率: +10%-- 不 100% 對於 2171 轉/每分 headspeed
0%
SW:F-S2
抵銷: {彌補:}  0
注意: 懶惰的 2種使用惡劣的數字從懶惰的 1 而且增加它是對它的自己價值。 {不作事 2種使用惡劣的數字從懶惰的 1 而且增加它是對它的自己價值。}  如此 90%(從懶惰的 1)+ 10%=100% {因此 90%(從懶惰的 1)+ 10%=100%}
8. 出口規畫菜單和查證那當你輕彈在你的收音機上的 AUX2 開關的時候,你能打開(綠色的)或者轉遠的 (紅色的)管理者。 {出口規畫菜單和查證那當你在你的收音機上輕彈 AUX2 開關的時候,你能打開(綠色的)或者轉遠的 (紅色的)管理者。 / 出口規畫菜單和查證那當你輕彈在你的收音機上的 AUX2 開關的時候,你能打開(綠色的)或者轉遠的 (紅色)管理者。 / 出口規畫菜單和查證那當你在你的收音機上輕彈 AUX2 開關的時候,你能打開(綠色的)或者轉遠的 (紅色)管理者。}  輪流。 如果必需的,你能顛倒來自顛倒 sw 的 AUX2 。 {如果必需的,你能從顛倒 sw 顛倒 AUX2 。}  在收音機上。
那它而且去有一些樂趣。
對 RR 的 george 0079 的特別謝謝。
ˍ_________________
安東尼
發表於 2007-11-27 23:21 |只看該作者
愚公大大真熱心呢  馬上就幫忙翻譯了一下  翻譯文裡面有些字會有點奇怪  希望tincor2005大大能揣摩一下  應該就會瞭解嚕
愚公大大  熱心翻譯  能讓我們飛友方便不少呢  謝謝嚕
發表於 2007-11-27 23:27 |只看該作者
愚公大大 …是用奇摩翻譯的啦!
.....遙控漫長的不歸路……
                                              /Coolpower30%
發表於 2007-11-28 01:30 |只看該作者
謝謝大家的分享!
260
小蝸牛
發表於 2007-11-28 01:45 |只看該作者
原帖由 tincor2005 於 2007-11-27 10:17 發表
前輩大大們     後輩是飛600N 遙控器用 DX-7 功能與 JR-2720 同 目前定速只會設 開與關 NORM過30%會啟動定速 常因誤以為在IDO模式..........就給它.....翻過去.......啊.......啊.......手不夠快............就 ...
掯~~誰叫你用DX7...
你看JR 2.4G現在連影子都沒看到
發表於 2007-11-28 16:08 |只看該作者
JR 2.4G不是沒了影子    朋友幫我8-9月落單訂的 9303 2.4G (9XⅡ)  等了3個月   剛剛在幾日前才收到......
應該是訂單太多  廠方未有太多貨賣....
[ 本帖最後由 村仔 於 2007-11-28 16:09 編輯 ]
(萬般帶不走為有3D GO!)
發表於 2007-11-28 20:34 |只看該作者
回復 #1 tincor2005 的帖子
          http://www.marzhobby.com/forum/c ... &extra=page%3D1
已冇法維有法,已有限維無限,用3D來靜化都市人心靈
發表於 2007-11-29 09:46 |只看該作者
感謝大大們熱心幫忙....後輩努力學習中.....目前還沒設定成功.....有沒有使用亞拓定器配備是dx-7或jr-2727遙控器的.....可提供資訊的....謝謝幫忙
小蝸牛....千萬別被偶看到....你換 2.4g商系統內
發表於 2007-11-29 20:34 |只看該作者
啊.........直接翻譯....有看沒有懂..... .........努力理解中
發表於 2007-11-30 19:20 |只看該作者
感謝tungym大資料及愚公大的"高難度譯文"協助後輩設定      今己搞定啦
設定程續如下
先將 ATV for AUX2 歸0成 +100%/-100%
重點 1 到主選單裡(開機開按住down+select+power鍵) 的Input Selct項目 AUX2設定成INH
       2 重新打開遙控器再到程式選單裡(按donw+select鍵)
       3 到混控程式PROG.MIX1 設定 NORM 不開啟定器  AUX2>AUX2  RATE:  0%
         4   混控程式 PROG.MIX2  設定IDLE1轉速   AUX2>AUX2   RATE: +90%
        SW:     F-S12
       5   混控PROG.MIX3         設定IDLE2轉速   AUX2>AUX2  RATE:  +10%
        SW:     F-S2
       6 再回到混控PROG.MIX1  設定成SW: F-NR
GMT+8, 2026-10-11 13:51
