查看: 1456|引用回復: 1
TP-1010C 最新V2.3a 介紹及支援電池規格
發表於 2007-9-28 22:16 |只看該作者 |倒序瀏覽
TP-1010C 最新升級程式 V2.3a 介紹及支援電池規格
遍尋不著V2.3a 支援的電池規格, 直接向原廠要.
給還在 Survey 充電器的你參考
PS: 感覺上, 似乎只要 TP 不倒閉, 新的電池規格可以一直支持下去, 是不錯的選擇.  從只支援 LP, 到 A123, Nimh, Nicd, PB 都靠 Firmware 昇級也支援了. 就是動作慢了點.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Quick reference and setup guide for
TP-1010C w/V2.3a software
Note: if you do not currently have V2.3a software installed in your charger, you can do so by downloading it from www.thunderpowerrc.com. You will also need to purchase a programming cable from Thunder Power or your local dealer.
Specifications:
Capable of charging/discharging 1 to 10 Lithium Polymer cells at up to 10A.
Capable of charging/discharging 1 to 30 NiCd or NiMH cells at up to 10A.
Capable of charging/discharging 6V, 12V or 24V lead acid batteries at up to 10A.
Capable of charging/discharging 1 to 10 A123 cells at up to 10A.
Note: The TP1010C is capable of 220 watts output which limits the max
current a pack can be charged at, e.g. a 5S Lipo pack could be charged at 10 amps
whereas a 10S pack could only be charged at 5 amps.
The TP1010C is capable of dissipating up to 2 amps max current with a power
limit of 22 watts, e.g. a 3S Lipo pack could be discharged at a maximum of 2 amps
whereas a 5S pack could only be discharged at 1 amp.
Navigating the software:
There are two basic sets of information that will be displayed on the screen, operational screen data, e.g. data that pertains to charging/discharging and setup screen data for the various kinds of charging/discharging that can be done with the unit.
There are 4 buttons on the front panel of the TP1010C. The buttons can be used in two ways, short presses (less than 1 second) and long presses (greater than 2 seconds). Generally, long presses are used to enter/exit setup menus and to commence charge/discharge. Short presses are used to change menu selections within the setup menus, change cell counts and currents and also to stop charging/discharging on the operational screen.
When first powered on, the charger will immediately display its manufacturer (Thunder Power), model number (TP-1010C) and software revision. Following that it will display the operational screen it was last used for.
If you want to use the currently displayed battery type, all you need to do from this point is to select, using short presses,
either charge or discharge using the 「SEL/MOD」 button, and then use the 「CHARGE/ENT」 button to select the cell count (displayed as 「XsPACK」) or current (displayed as 「C or D =X.XXA」. From here the 「-/DEC」 and 「+/INC」 buttons are used to alter the numerical value (the X』s) of these two parameters.
To enter the setup menus, long press the SEL/MOD button. The display will show 「Battery type」 and a chemistry, most likely 「LiPo」. To change the type of battery, push either the 「-/DEC」 or 「+/INC」 buttons to scroll through the 5 available chemistries. Once the proper type has been chosen, short pressing the 「SEL/MOD」 button will take you through the various parameters that can be changed for that type of battery. The following tables show these parameters along with a description of each and a range of adjustment.
NiCd/NiMH
Function
Purpose
Adjustment range
Delta -V setting
Sets the -V trip point at which the charger stops charging
5-20mV (NiCd
2-10mV (NiMH)
Cooling fan mode
Lets you turn off the fan if not needed
Always on or auto
Key tone option
Lets you turn off the beeping when buttons are pressed
On/Off
Input PWR option
Sets the threshold for minimum input voltage
10-12V
LVC
(Keeps you from having to ask your buddy for a jump start)
System timeout
Sets the maximum time for a charge cycle
2 to 10 hours
max time
Cycle data Cy#:1-9
Shows the charge and discharge capacities for up to 9 cycles.
Can view any of 9
previously run cycles
PB (lead acid)
Function
Purpose
Adjustment range
PB charge topoff
Adjusts the per cell final voltage at charge termination
2.2-2.5V
Cooling fan mode
Always on or auto
Key tone option
On/Off
Input PWR option
10-12V
System timeout
2 to 10 hours
Max time
A123
Function
Purpose
Adjustment range
A123 charge option
Allows adjustment of the amount of charge put into the battery
100%
95%
50% (storage)
FAST charge (almost
a 100% charge but
not taking as long)
A123 Dchg option
Sets the per cell cutoff voltage when discharging
2.5-3.6V/cell
cut off
Li/A1 InitCharge
Sets the maximum time the charger will take to initialize
5 to 15 minutes
timeout
a charge procedure
Cooling fan mode
Always on or auto
Key tone option
On/Off
Input PWR option
10-12V
LVC
System timeout
2 to 10 hours
Max time
LiPo
Function
Purpose
Adjustment range
LiPo CHG option
100%
95%
50% (storage)
FAST charge (almost
a 100% charge but
not taking as long)
LiPo Dchg option
3 to 3.9V/cell
cut off
Li/A1 InitCharge
5 to 15 minutes
timeout
a charge procedure
Cooling fan mode
Always on or auto
Key tone option
On/Off
Input PWR option
10-12V
LVC
System timeout
2 to 10 hours
Max time
Once you have dialed in all the specifics for the battery you want to charge or discharge, long press the 「SEL/MOD」 button again and you will be taken back to the operational screen.
From the operational screen, to select charging, discharging or cycling, you short press the 「SEL/MOD」 button. To change the number of cells or charge/discharge current, you short press the 「CHARGE/ENT」 button which will initiate blinking of either the Pack size or charge/discharge current. From here you use the 「-/DEC」 or 「+/INC」 buttons to alter the numbers. Once the proper numbers have been set, long press the red 「CHARGE/ENT」 button to initiate charging, discharging or cycling. Note that short pressing the red 「CHARGE/ENT」 button also halts the current charging, discharging or cycling process.
As a battery charges or discharges, information is given on the main screen. In the upper left of the screen you will see two letters that change every two seconds, these are the battery type and
function being performed. Just to the right of that you will see the current voltage across the pack. To the right of that you will see the charge current. Just to the right of that you will notice that there is another character that changes back and forth, this will show either A for amps, CC for constant current or CV for constant voltage depending on what kind of charging you are doing. The second row of the display shows the amount of charge placed back into the pack in mAhrs and overall charge time.
If using a balancer in closed loop mode, you can at any time during a charge or discharge cycle (LiPo and A123 only) check to see any of the individual cell voltages. Long press the 「SEL/MOD」 button until a screen with CH and CL are displayed on the far left end. From here you can use the 「-/DEC」 and +/INC」 buttons to scroll through the cells, two per screen. To the far right of these screens you will also be shown the maximum deviation voltage between cells. Leaving the unit alone for about 6 seconds will return it to the charge screen.
Using memories:
From the main charging screen, the one that you initiate charging from, there are three parameters that you can alter, the cell count, charge/discharge current and memory position. At the far upper, right end of the display you see [M 1-10], this is the memory location. To access it short press the red 「CHARGE/ENT」 button quickly and the number in the brackets will begin to flash. You can use the 「-/DEC」 and 「+/INC」 buttons to change the location. Note that each location will keep the cell count and charge current stored. There are 10 memories per battery type for a total of 50 memories. Note that the memories cannot be named other than 1, 2, 3 etc. but you could number your packs accordingly, NiCd pack 1, Lipo pack 1 etc.
發表於 2007-9-29 00:43 |只看該作者
好東西!感謝
GMT+8, 2026-10-11 02:16
