查看: 1797|引用回復: 8
How to set JR G490T with JR PCM 9XII
發表於 2007-6-26 11:22 |只看該作者 |倒序瀏覽
Hi Every Brothers,
I am from HK and wonder anyone can help to advise how to set JR G490T Gyro with JR PCM 9XII transmitter and  JR RS10DS receiver?
- Heli is Align 450S
- rudder servo is Futaba 3154
Sorry that I cannot type Chinese but I am learning now.  That is one of the many good things I have got after start palying RC Heli.
Manyyyyyyyyyyyy thanks.
發表於 2007-6-26 11:47 |只看該作者
請問您有陀螺儀的說明書嗎
應該上面會有詳細的說明
手邊沒這顆 所以 沒辦法幫忙
也許 可以試著找購買的模型店問看看
發表於 2007-6-26 12:06 |只看該作者
This is PCM9XII manual. Page26 explains G490T set-up.
http://www.macgregor.co.uk/radio/PCM9XII.pdf
This is G410 manual. The content must be more and less the same as G490T.
http://www.modelflight.com.au/ma ... _jr_g410_manual.pdf
Have fun
離開是因不願住在井裏
切斷臍帶才能走的更遠
發表於 2007-6-27 09:01 |只看該作者
回復 #2 pico 的帖子
Anyway, thanks for your very kind attention.
發表於 2007-6-27 09:06 |只看該作者
回復 #3 gwagwa 的帖子
My problem was I cannot lock the head.  However, your information (... Page 26 ...) is very usaful.  I believed I fixed the problem last night and I will test it on Saturday.
Mannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnny thanks.
發表於 2007-6-27 15:49 |只看該作者
Please report your result share with the entire Align fly fans here.
[ 本帖最後由 lchgti 於 2007-6-27 15:53 編輯 ]
發表於 2007-6-28 14:20 |只看該作者
回復 #6 lchgti 的帖子
Ha,  I just found a useful information of G490T which would like to share with all of you :-
http://www.graupner.de/fileadmin ... nleitungen/5137.pdf
There is English version at the middle of the article marked "Gyro System SRVS G490T Operating Instructions"
Cheers
發表於 2007-7-3 11:19 |只看該作者
回復 #6 lchgti 的帖子
I tested my heli yesterday and it was very stable.    The settings are as below :-
JR PCM 9XII
Gyro Sens
Rudd D/R
Pos 0 : 80%
Pos 1 : 100%
Below is the explanation of head lock mechanism for JR G490T gyro :-
www.macgregor.co.uk/faq/Gyros/G490T_Settings.htm
Others, just follow the gyro mannual.
Cheers
發表於 2007-7-3 12:27 |只看該作者
Cool man! (cm)
離開是因不願住在井裏
切斷臍帶才能走的更遠
GMT+8, 2026-10-11 15:45
