查看: 804|引用回復: 4
Futaba 3101 micro servo on Trex 450
發表於 2007-4-12 17:31 |只看該作者 |倒序瀏覽
Any people try to put the Futaba 3101 micro servo on Trex 450 like this?
發表於 2007-4-12 18:49 |只看該作者
:bem16:bem16
越來越無言了~~
發表於 2007-4-12 19:31 |只看該作者
會~~~~~~~~~不會太大顆了~~~~
JR  PCM  10X~~~~~72頻
發表於 2007-4-12 21:51 |只看該作者
Futaba 3101
Speed: 0.14 sec/60 deg@ 6V
Torque: 3.1 kg-cm @ 6V
Length: 1.1" (28mm)
Width: 0.5" (13mm)
Height: 1.2" (30mm)
Weight: 0.6 ounce (17 grams)
Connector: "J" type with about 5" wire
May be Futaba S3102 with Metal gear and over 4Kg-cm@6V
發表於 2007-4-13 03:09 |只看該作者
what's the different is ? i can't tell !
對不起請問有什麼特別?
GMT+8, 2026-10-17 00:59
