查看: 958|引用回復: 0
XtremeLink 2.4GHz ISM bands RC module
發表於 2006-11-20 22:50 |只看該作者 |倒序瀏覽
聽說快上市了!!!(Maybe befroe X'mas...)
亞拓有沒有考慮代理啊?
期待不用擔心被甘擾的日子.....
跟據XtremeLink官網...Danny Szabo 已經試用在大暴龍上了!!!!!!
Detail see below link...
http://www.xtremepowersystems.net/xtremelink.php
XtremeLink™ Features:
Range
Up to 1 mile (5200+ feet) ground based, line of sight.
Up to 5 miles (26,000+ feet) ground to air, line of sight.
Frequency
2.4GHz ISM bands, using intelligent frequency hopping.
Spherical RF radiation technology eliminates the need for multiple antennas.
Resolution
16 bits per channel (65536 system).
+/- 10ns servo pulse accuracy.
Interference(甘擾)
1 in 18,446,744,073,709,552,000 chance of being on the same channel as another module (and that's only if we sold that many systems + 1!)
Up to 160 modules in use simultaneously.
Antenna length
1.2" for both receiver and transmitter, fully enclosed.
Miscellaneous
Programmable failsafe for all channels (in event of transmitter battery failure).
Programmable channel mixing, swapping, and duplicating.
Bi-directional telemetry data interface.
FCC, IC, CE, and ETSI approved!
Specifications:
8 channel receiver -
Dimensions:  2.115" x 1.125" x .525"
Weight: 19.15 grams (.675 oz)
Input voltage: 3.5v to 16.0v
10 channel receiver -
Dimensions: 2.115" x 1.315" x .525"
Weight: 21.50 grams (.758 oz)
Telemetry modules -
Dimensions: 1.25" x 1.05" x .45"
Weight: variable
Output voltage: receiver battery voltage
GMT+8, 2026-10-10 00:15
