查看: 1395|引用回復: 7
JR新控
發表於 2006-6-1 13:16 |只看該作者
發表於 2006-6-1 13:18 |只看該作者
請問 :有哪位高手用過NEC GY400陀螺,跟GY401比差多少? smiles-dem37.gif
發表於 2006-6-1 13:56 |只看該作者
QUOTE (liuguanze @ Jun 1 2006, 02:15 PM)
離開是因不願住在井裏
切斷臍帶才能走的更遠
發表於 2006-6-1 14:25 |只看該作者
QUOTE (gwagwa @ Jun 1 2006, 01:53 PM)
就是GY400
發表於 2006-6-1 14:28 |只看該作者
GY400
發表於 2006-6-1 15:06 |只看該作者
離開是因不願住在井裏
切斷臍帶才能走的更遠
發表於 2006-6-1 15:40 |只看該作者
QUOTE (liuguanze @ Jun 1 2006, 02:22 PM)
就是GY400
發表於 2006-6-5 09:58 |只看該作者
點圖放大
7202 Synthesized PCM Heli 4-DS821 R790
Specs
 # of Channels: 7 Channel
 Modulation: PCM & PPM
 Band: Fully Synthesized Transmitter
 Servos: DS821 Sport Digital Servos
 Receiver: R790 Scan Select PCM
 Programming Features: Aircraft and Heli
 Model Memory: 20 Model Memory
 Transmitter (Tx) Battery Type: 1500mah NiMh Battery
Tech Notes
Transmitter :
XP7202
7 Channel
20 model memory
Aircraft and Heli programming
S-PCM (as supplied) Z-PCM and PPM (FM)
Fully Synthesized Transmitter (Frequency selection is part of the programming)
Fully Digital trims
Receiver:
PCM Modulation
7 Channels
DSC capable
Servos:
Torque 72 oz/in @ 4.8V, 88 oz/in @ 6.0V
Speed .19 sec/60 deg @ 4.8V, .15 Sec/60 deg @ 6.0V
Size: 1.50」 X .94」 X 1.47」
Weight: 1.5 oz
Ball-Bearing: Single
Motor: Cored
System Mode
Model Select
Model Name
Model type Select
Modulation Select
Model reset
Trainer system select
Throttle Recovery
Input Select (Switch Select-ability for Aux 2 and Gear)
Wing type
Swashplate type
Frequency Selection (Ch 15 - 60)
Dual Rate Switch Select
Airplane Function Mode
Dual Rates
Exponential
Servo Reverse
Sub trim
Travel Adjust
Elevator to Flap Mix
Aileron To Rudder Mix
Flap System
Differential
Programmable Mix (1-6)
Fail Safe
Servo monitor
Helicopter Function Mode
Dual Rates
Exponential
Servo Reverse
Sub trim
Travel Adjust
Swashplate Mix
Throttle Hold
Throttle Curve (3) (5 pt mix)
Pitch Curve (4) (5 pt mix)
Revolution Mix
Gyro Sensing
Fail Safe
Servo monitor
GMT+8, 2026-10-10 11:50
