查看: 818|引用回復: 9
新手問一些問題
發表於 2005-12-2 18:59 |只看該作者
發表於 2005-12-2 19:11 |只看該作者
發表於 2005-12-2 19:12 |只看該作者
謝謝  那.T-REX 450XL(HDE)她就不能做一些動作是媽
發表於 2005-12-2 19:25 |只看該作者
QUOTE (aa0416001 @ Dec 2 2005, 07:12 PM)
沒錯~
你所說的遙控器屬於飛機六動的,使用Y型線就可以玩小暴龍ㄌ!
小東遙控模型專賣店~ 歡迎新飛友加入~
電話:03-3259199 03-3259166
地址:桃園市慈文路160號
發表於 2005-12-2 19:36 |只看該作者
This is the Futaba 6EXA 6 channel FM Computer Radio System with four S3004 standard size ball bearing servos. This system is designed for the first time modeler that prefers a computer style radio.
***THIS RADIO CONTAINS NO HELI PROGRAMMING***
FEATURES:
Compact ergonomically designed transmitter holds completely independent memories for six different models.
Standard programming features include all channel servo reversing, End point adjustment (EPA) on all channels, dual rates, exponential flaperon, V-tail, elevon, and wing type selection.
Transmitter controls include Throttle Cut Switch-stops engine when flipped twice within one second, Trainer Switch-controls link between instructor and student transmitters, Retract Switch- controls operation of retractable landing gear or other feature, Dual Rate Switch-reduces servo travel and switches exponential curve
Flap Knob-controls flap servo. By using the supplied flap control lever modeler can set the maximum up deflection of flaps. This feature prevents flaps being accidently applied as spoilers during flight.
New stick design provides an improved feel. Sticks' length is adjustable.
Trainer box capable (trainer cord sold separately, see COMMENTS).
INCLUDES: One Futaba 6EXA Computer Radio system with:
R127DF FM Dual Conversion Receiver FUTL0702 (lo band) FUTL0703 (HI)
Four S3004 Ball bearing servos FUTM0004
One bag servo mounting harware NR-4J Receiver battery FUTM1280
NT8F600B Transmitter battery FUTM1440
FBC-8B(4) Charger FUTM1800
SWH-13 Switch Harness FUTM4370
ANT-5 Transmitter Antenna FUTM5040
Servo Extension FUTM3910
REQUIRES: Charging transmitter and receiver batteries
SPECS:
Receiver- Type: Dual conversion
Power requirement: 4.8v or 6v Ni-cd battery
Current drain: 14mA @ 4.8v
Length: 2.52" (64mm) Width: 1.39" (35.3mm) Height: 0.82" (20.8mm)
Weight: 1.5oz (42.5g)
發表於 2005-12-2 20:02 |只看該作者
發表於 2005-12-2 20:24 |只看該作者
看紅字的地方
就是說 他不支援直升機模式的混控
就要用東仔大說的
只能用Y型線 連動油門和螺距
這樣做 調整的部分比較沒辦法很細緻
倒飛的部分也沒辦法設定
要調整到很好飛 也要花很多時間嘗試
比起直昇機專用的發射器 麻煩很多
有一兩位大大用ALIGN 小黃發射器在飛小暴龍
當然 技術好 除了不能倒飛
一樣也是可以飛得粉衝
提供參考
把原來的規格PO 上來
順便讓您知道自己的發射器的詳細諸元
才能夠更瞭解他喔
發表於 2005-12-2 20:42 |只看該作者
感謝板主小弟準備給她敗一台來玩
不隻買空機還是買套裝
發表於 2005-12-2 20:45 |只看該作者
QUOTE (aa0416001 @ Dec 2 2005, 08:42 PM)
感謝板主小弟準備給她敗一台來玩
不隻買空機還是買套裝
發表於 2005-12-2 20:46 |只看該作者
感謝板主小弟準備給她敗一台來玩
不隻買空機還是買套裝
GMT+8, 2026-10-15 06:29
