查看: 1130|引用回復: 3
電變 governor mode
發表於 2005-8-28 09:50 |只看該作者
Align motor 420LF KV3200 + Phoenix25, use High governor or low governor?
發表於 2005-8-28 16:21 |只看該作者
High governor
發表於 2005-8-28 20:39 |只看該作者
QUOTE (wells @ Aug 28 2005, 04:26 PM)
High governor
what is different between high governor and low governor mode?
發表於 2005-8-30 15:48 |只看該作者
I just found the information on RCGroups:
Low Governor Mode:
16000 RPM/pole (1ms)
100082 RPM/pole (2 ms)
High Govenor Mode:
106493 RPM/pole (1 ms)
337508 RPM/pole (2 ms)
I show three examples. First, assume the gear ratio
is 150T/15T = 10
A. Low governor mode + 2 poles motor.
  Max. motor speed is (2mS pulse) : 8000 rpm
  Min. motor speed is (1mS pulse):  50041 rpm
  Max. head speed:  800 rpm
  Min. head speed:  5004 rpm
  50% of throat is about 2500 rpm
B. Low governor mode + 12 poles motor.
  Max. motor speed is (2mS pulse) : 1333 rpm
  Min. motor speed is (1mS pulse):  8340 rpm
  Max. head speed:  133 rpm
  Min. head speed:  834 rpm (TOO LOW)
C. High governor mode + 12 poles motor.
  Max. motor speed is (2mS pulse) :  8874 rpm
  Min. motor speed is (1mS pulse):  28125 rpm
  Max. head speed:   887 rpm
  Min. head speed:  28125 rpm
  90% of throat is about 2500 rpm
GMT+8, 2026-10-11 06:10
