查看: 1851|引用回復: 10
problem of 20A brushless esc
發表於 2004-10-14 13:37 |只看該作者
Hello,
I am coming from Hong Kong. My friend bought me an 20A brushless esc when travel to Taiwan.
I didn't fly this esc yet, i just test it in home. after i change the setting of motor angle and cut off voltage, my esc doesn't beep any more. Is the esc dead? can you help me? the esc doesn't get hot and i removed the cover and didn't see any damage.
smallming
發表於 2004-10-14 15:44 |只看該作者
smallming
Hi smallming,
I'd suggest you to contact Align's QC department via e-mail in Chinese. The e-mail address was
[email protected]
I think they will do a troubleshooting and arrange a replacement if needed.
9
發表於 2004-10-14 16:26 |只看該作者
smallming
Do you connect the esc to your motor?
The sound "beep" is come from motor not esc, so you should connect the motor first.
引用回復
舉報
發表於 2004-10-14 20:49 |只看該作者
yes, the i have already connected the motor, the motor can work with my jeti esc and can beep before i change some setting.
it just no beep and the motor not response, servo can work.
9
發表於 2004-10-14 23:57 |只看該作者
esc and motor are workable.
發表於 2004-10-15 08:42 |只看該作者
can not recall the the previous setting, because no beep.
9
發表於 2004-10-15 10:57 |只看該作者
QUOTE
Do you have another brushless motor or esc to test?
To test esc and motor respectively, maybe you can find which one is broken.
發表於 2004-10-15 10:59 |只看該作者
yes, as i said from my 1st post, i have used the jeti esc to test, motor no problem
發表於 2004-10-15 15:06 |只看該作者
我也試過同樣情況, 現正送到原廠維修
發表於 2004-10-17 11:23 |只看該作者
Maybe you can send the mail to Align first, the customer service dept will give you a good respond and speedy.
發表於 2005-10-17 15:29 |只看該作者
QUOTE (smallming @ Oct 15 2004, 08:42 AM)
try to reconnect the power plug for some times util u hear the beep sound, and try to pull the throtle stick up to the most to enter the setup mode.(maybe u've setup the wroung setting, so they don't beep anymore)
返回列表 發新帖
GMT+8, 2026-10-11 20:30
